hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
hognit09
- Mar 7, 2010
- beaver dam, wi.
Whoops meant AFR guage
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
Are you adding a Power Commander to adjust fuel? Is that why you need the gauge?
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
You will definitely need a power comander with a map if you do anything with your airbox and add an exhaust. Probably going to need to do some clutch work also.
hognit09
- Mar 7, 2010
- beaver dam, wi.
After talking to someone, they thought the latest flash only was lean out on start and idle. A lot of people are running both with no problems, don’t know if this true with flash but was thinking of getting an afr guage first to see if a pcv is necessary
TPAY243
- Apr 14, 2013
- Northern Wis
You can do what ya want but I'm telling ya your going to be lean and will end up losing hp. You need to add fuel to make these add on's work properly. I'm not 100% sure but the ECU is probably lean from the factory to meet emissions. I guess you could put the AFR gauge on there and see where your at if it is good run it, if not you'll have to get a programmer.
hognit09
- Mar 7, 2010
- beaver dam, wi.
That’s what I was considering. Waiting for EVO fix there machine for ecu programs as I would rather have that then a pcv
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
I have been running the AEM for almost 11k miles. Works great. Numbers are a little small to see at WOT but other than that no issues.Is anybody using this afr guage ? Really wanting to do the airbox mod, and already have an EVO can with a bung already welded on.
hognit09
- Mar 7, 2010
- beaver dam, wi.
How did you mount the guage ?
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
You can buy a bracket or make one yourself.How did you mount the guage ?
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
I put my boost and AFR gauges to the left and right of the heat vent in front of the handle bars. There is a good flat spot there. I have a pic on my turbo install thread. If I didn't have a GPS I would have mounted it just above the instrument cluster with a RAM mount.
