Daranello
Suspended
Yesterday, riding in -25c weather xing a snowbank at the creast i slowed to make sure there was no cars or trucks, as I hit the gas again the clutch slipped, I let off the throttle immidiatly but it was too late the RPMs raced to 7500 and to sled let off sninky belt smoke.....
latter in the day we were playing in a bowl and doing some hill climbs and again I was experiencing belt slip again, but not as bad.
My Attak never ever slipped,
when I got home I looked at the belt and its didnt look flat spoted, so I'm guessing that the secondary slipped and not the primary, espectialy the fact that I didnt ease into the trottle.
So whats the problem guys??? the sled only has 250miles and yes I broke in the belt and washed the belt before install
Bamboo
Broke in the belt?? Wha?? How does one break in a belt???
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
By taking it easy for the first 50 miles, at least that's what I've always heard and done.Bamboo said:Broke in the belt?? Wha?? How does one break in a belt???
Daranello
Suspended
Every new belt needs to be seated to the clutch faces. To accomplish this, it is recommends that you run your sled for the first 30 miles at half throttle or less. This will allow the belt to conform to the angle of the sheaves, producing more surface contact thus enabling the belt to transfer the most horsepower at the highest efficiency
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Depending on how deep of snow you were in, a small ammount of snow could have made its way to the belt area and gotten the sheaves wet? had that happen before...
Daranello
Suspended
nate007 said:Depending on how deep of snow you were in, a small ammount of snow could have made its way to the belt area and gotten the sheaves wet? had that happen before...
that i know forsure didn't happen cause were just left a coffee shop to warm up and we were xing the parking lot (no snow) and the snowbank was hard like a rock
belt
If you had the sled sitting outside for a while and then you went across a parking lot with no snow, it probably was just a lot of a stress on a cold belt. My guess is that once you got the belt warmed up and were back on snow the slipping stopped. I have had my belts slip on 1st of the day trips across a powdery lake, once the belt warmed no problem.
jds1000
Also if the clutches were cold there may have been some condensation on the secondary from sitting in the parking lot.
Turk
Tech Advisor
Your secondary clutch was probably stuck in a partially open position. happens a lot if your on & off the throttle or especially after a real quick stop.
Daranello
Suspended
So the belt should be ok, since it spun in the sencondary???
Turk
Tech Advisor
Sorry
Can,t see your belt from here.
jds1000
Turk said:Sorry
Open your eyes Turk!! I can see it and yes it looks fine to Me!
NB-NYTRO
If you got belt smoke chances are you got a flat spot somewhere. But Turk is right the secondary is wrapped tight and it sometimes stays open if you stop quick.
Daranello
Suspended
NB-NYTRO said:If you got belt smoke chances are you got a flat spot somewhere. But Turk is right the secondary is wrapped tight and it sometimes stays open if you stop quick.
Yeap, it smoked like a 2 stroke at start up!
