Ryanmlt1
Hi guys, still new here. My 06 Attak with 4900 mi. has what I would call Salt stains? Not sure what else to call it. Its bare aluminum, I know some are painted. Its slightly discolored with green and whitish marks. Most likely from being trailer'd and not being washed after.
Is there anything I can use to polish it out. I'm not looking for a mirror finish just to get the salt and greenish tinge out.
YammyRX1
Try Mother's Billet Polish, it seems to be the most popular product here for a quick shine. Next step up would be to buy a kit that contains buffing pads and compound for a high speed drill- and for true mirror finish get out lots of fine grit sand paper and start wet sanding.
ranger1
Aluminum polish, angle grinder & buffing pad.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
I would try a pre-wash/scrub with some baking soda/powder water solution first just to see if that helps any with the staining?
If so, then a quick polish with whatever product you choose will be all it needs.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Flitz, comes in a toothpaste tube, great stuff. Reacts great with aluminum.
Mothers works well but if it really oxidized it doesnt bring it up to a mirror finish. You have to do it multiple times and tons of elbow grease, the Flitz stuff is way more agressive on the metal.
MS
MS
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Irv said:I would try a pre-wash/scrub with some baking soda/powder water solution first just to see if that helps any with the staining?
X2
Fine Steel Wool works great.
Ryanmlt1
Wow thanks for the responses guys. Its fairly common sense stuff, but the tips and choosing the right brands are really helpful.
machzrobbie
Kaz
Where are you purchasing the White Diamond Polish in Ontario?
Kaz
Kaz
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Kaz said:Where are you purchasing the White Diamond Polish in Ontario?
Kaz
X2?
sgauthier
most truck stops carry it. i know the fifth wheel in Milton has it as well as the one in Woodstock.
YammyRX1
sgauthier said:most truck stops carry it. i know the fifth wheel in Milton has it as well as the one in Woodstock.
Cool, I pass by the 5th Wheel twice a day so might have to check that out.
yamadog1
polish
if it's bad, wet sand with 2000 grit first and polish and buff much easier.
Sno Cat
I've 1st cleaned w/a WD40-soaked rag to get the grime off, then wipe a clean rag to remove residue then follow up w/Never Dull. Doesn't leave a mirror finish but I don't want that anyway. This is a quick-n-easy process
