Yamahnator
This is a 2011, my 2007 had a definite A arm look to it. But these are parallel to the ground. Also Pressure in shocks is 75. That a good number?
Looks to be sitting low at that pressure.
Yamahnator
I raised the pressure to over 100 but it didn't seem to change any of the geometry.Looks to be sitting low at that pressure.
Strange
20/80
Are you running snowtrackers on your skis? 100psi should have raised your sled a bit more, your a arms should show a bit more angle with 100psi, did you take the weight of your skis when you added more pressure.
You checking pressure with skis off the ground?
Yamahnator
I did not. Thanks for reminding me, it's been quite a few years lolYou checking pressure with skis off the ground?
Yamahnator
I am not running snowtrackers.Are you running snowtrackers on your skis? 100psi should have raised your sled a bit more, your a arms should show a bit more angle with 100psi, did you take the weight of your skis when you added more pressure.
Yamahnator
I feel like an idiot now. Ironic since the cheapo jack in the picture I had just bought for sleds and bikes is in the picture close enough to bite me.... Corrected the problem. Do people take all the pressure out usually for the summer or do they slowly lose pressure? It's been several years since I've had fox floats.You checking pressure with skis off the ground?
Could have leaked out over time. Pump them up and see if they hold.70psi should be good. If they leak can use some soapy water of better yet put in tub and see where. Common to find Schrader valve leaking from corrosion. Can try a little lube in there and if that doesnt work replace the core. Same as car tires use.I feel like an idiot now. Ironic since the cheapo jack in the picture I had just bought for sleds and bikes is in the picture close enough to bite me.... Corrected the problem. Do people take all the pressure out usually for the summer or do they slowly lose pressure? It's been several years since I've had fox floats.
Yamahnator
Alright great, thanks for the advice!Could have leaked out over time. Pump them up and see if they hold.70psi should be good. If they leak can use some soapy water of better yet put in tub and see where. Common to find Schrader valve leaking from corrosion. Can try a little lube in there and if that doesnt work replace the core. Same as car tires use.
- 113K
