Dodge Ram
Just need some help. Anybody have a easy way to drill an easyout. Broke an exhaust bolt off in the head. Not much room in there to get a regular drill bit. Was thinking of pulling the head off or pulling the engine next.
Any help would be great.
1975FA
Easy outs are a joke. I usually weld a nut to broken studs. stuff a damp rag in the ports when you are welding to keep slag out. I just did a head gasket in my nytro. It took me 5hrs to pull the engine and get the head off and another 10hrs to put it all back togeather. You have to pull the engine to take off the head.
arteeex
Did the bolt snap at or near the surface of the head? Is there anything left that you clamp a vise-grip on and apply some heat?
Those are not large bolts - 8mm - the easyout route is going to be tough to do without securing the head and drilling precisely.
Note for next time - use hi-temp antiseize compound when you reinstall.
Nine2Nine
What's in there the bolt or the easy out? A carbide drill will drill out both but you need a quality easy out, they make them.
Indy
i've never seen a good easy out, don't know why they are even called that, should be never-out.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Depending on the brand sometimes you can melt them out with a torch
Dodge Ram
Not enough metal for a vise grip. Broke off flush with head. Both bolt and easy out are in there. Going to try and use my buddy's Mig to weld a bolt on there. And use more heat. Ya never seize would have been nice if the factory put it on the bolts. Currently making a new plug for my generator to plug into his welder. 4 plug into 3 plug. I use to wled for a living years ago so we sholud be able to get this down. The easy out was from O riley's. Can't remember company name. But I was sure pissed off when it snapped off. Gonna remove other heat shield (lower one) so I can get an andled drill in there. Not much room for drill and bit.
Thanks for all the replies and suggestions. I will let every one know if I get it out incase somebody else has a broken flex pipe and ends up in my situation.
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Get yourself a good sharp pointed carbide burr and grind it out with that. One of the few things that will cut a easy out. Be prepard to spend a few bucks on it though.. Once you start to grind it out you can usually get in and chip away at the surrounding area and break out some peices as you go..
For easy out(or extractors) we bought a set from Mac tools that works pretty good. You have to use moderation with them too but they do work pretty good. There's a set it almost every mechanics tool box around here.. reasonlably priced too. 110 dollars for a set that gose from 1/8" to 7/8" if I remember correctly. Been a bit since I looked at it so can't say for sure..
I don't konw how much room you have or what all is surounding it but heat is definatley your friend if you can safely do it without heating anything else up to hot..
Good luck. It's a frustrating job to say the least..
Ryan
Ryan
Dodge Ram
Thanks Ryan I will look into a carbide burr.
meskie
Weld a nut on. Find on the same size as what your trying to remove and weld up the middle. The heat will break it loose. Wait for it to cool and turn it out. Have done lots this way. If you don't let it cool enough you will have to weld a new nut on and try again
Easy outs do work on some things rather well, not the tapered rectangled ones with the sharp edge but the cone shape ones with the spiral twist.....they work so much better.
Forget about drilling those things out if you break one
Your right welding a nut over it most often works the best
Nine2Nine
Alatalo
Removing the lower heat shield and the secondary shaft will give you a lot more room and they are less time consuming than removing the engine.
peppahillcustom
Weld a nut to it we have run into it more than once at my shop with harleys and numerous different cars. Use an impact when trying to remove as the heat from the weld and the vibration from the impact work very well together. It may take a few tries but it does work have done it many many times
Dodge Ram
All Great Ideas and I am going to get my buddies mig this am. Then to Home DP to get a grade 8 bolt to weld onto the broken one. I will try everthing before I pull the head. Just won't be going sledding till I get this thing done. Hindle should be here today and skid plate.
