acesfan05
I am going to put the Excell Exhaust with the header and Power Commander. Has anyone does this exact install? and if so, how long did it take you?
Any details would be appreciated...
Thanks,
Will
Thanks,
Will
Northernboy
Should only take a few hours taking your time. It is very straight forward and simple. The only tough part was bolting the clamp around the Excell muffler with the cover on. I ended up drilling two holes in the cover so I could use a socket and ratchet from the outside of the cover. After I was done I covered the holes with aluminum tape. Made the job easier. Might consider putting in some new plugs while you have the gas tank off.
Good Luck
NB
Good Luck
NB
acesfan05
So taking the gas tank off is no biggie eh?
Northernboy
Taking off the tank is no problem, 2 nuts, fuel line, fuel pump wiring, fuel level wiring and about 8 of the plastic clips. Very simple.
nytroD
3 hours minamum, if your a decent mechanic.Instructions were garbage & ended after the removal of the old header. Reinstalling the old header bracket is the worst part of the job. Fit & finish on the new header is perfect. Allen said no power comander was required,so spend your money on clutching.
Yamahnator
nytroD said:3 hours minamum, if your a decent mechanic.Instructions were garbage & ended after the removal of the old header. Reinstalling the old header bracket is the worst part of the job. Fit & finish on the new header is perfect. Allen said no power comander was required,so spend your money on clutching.
Nah won't take that long. Installation pretty smooth. I don't know why he'd recommend no power commander.
SISCAKIDD
Yamahnator said:nytroD said:3 hours minamum, if your a decent mechanic.Instructions were garbage & ended after the removal of the old header. Reinstalling the old header bracket is the worst part of the job. Fit & finish on the new header is perfect. Allen said no power comander was required,so spend your money on clutching.
told me no power commander needed.unless i have a hesition,so far so good.
nytroD
Make's sense because all efi systems can compensate for more or less fuel, ie air temp. & elevation. My understanding is only intake & exhaust mods would require more fuel. Exhaust only--no. Siscakidd, how long did your install take?
SISCAKIDD
3 hours including taking the gas tank off twice because i forgot to put the the heat shield on,was in a hurry to hear that bad boy bark.
Make sure you take Northernboy's advice on drilling two holes in the heat shield. I tried every type of socket, universal joint, and wrench, to tighten the nuts on the muffler clamp. Then I stared at the thing for about another half an hour before drilling the holes.
