Nytro Fx
Well i am almost done, everything has went well. But it tells me to out the secondary spring into #3 but there are no #'s. Is there another way i can find the #3 hole?
Thanks cameron
Thanks cameron
unpride
Keep looking its there! Then wait till the dialing in begins with the super tips. I almost had my sled over backwards the other day playing with weights. Have fun!!!
Nytro Fx
i have been looking, were should the #'s be?
unpride
You will see a 1 and a 3 barely. Try cleaning the sheaves real good. You can barely see the numbers right above the holes.
Nytro Fx
ok will try.
Nytro Fx
ok well if cleaning them doesnt work, can i use a reference point to find #3 hole?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The numbers go 1,2,3 in a counter clockwise direction!
Nytro Fx
Ok, but i can not find any #'s
- Apr 17, 2003
- Menno, SD
- Menno, SD
The stock spring was in the #2 spot. If you can see where that is it will give you a reference.
Nytro Fx
ok, i think i have found were #2 is, how hard should i have to turn to get it to the correct spot to line up with the bolts? also what happens if i am wrong?
unpride
Have you looked at Ulmers instructions? They are very good and detailed
- Apr 17, 2003
- Menno, SD
- Menno, SD
Hopefully this helps you. This is roughly how much you should have to turn it clockwise to get the helix on!
Nytro Fx
ok thanks its all cleared up now
