NytroMisfit
- Feb 18, 2015
- Levant, Maine
- 2009 nytro xtx
Im guessing code 13 is for the pressure sensor which locks the air pressure at a safe median.
Then code 22 is for the temp sensor which locks it at a safe temp.
With the tuner you are using are you able to adjust ECM parameters such as the air temp range?
Just feel like the atmospheric variables are outside the parameters of the stock ECM and the ECM is retarding timing to keep the engine safe which would explain the bogging when heated up.
Sorry If I'm not a help I am coming strictly from automotive experience not Sled
NytroMisfit
- Feb 18, 2015
- Levant, Maine
- 2009 nytro xtx
You also said you were having issues with your 02 sensor. Did you ever end up getting any AFR's when you were having the bogging issues?
vollender
- Jan 22, 2012
On the afr gauge at idle it was 13.5, Then when on the 2 step it went full right and gauge goes to 16. Then on launch it goes right to 12.5, just what it is set for and recommended. with the launch so rich we were 2 10s slower in the 60'.
NytroMisfit
- Feb 18, 2015
- Levant, Maine
- 2009 nytro xtx
And it stayed the same even when you were experiencing the slower times. Do you have engine temp readings?
sent using my personal communication device
vollender
- Jan 22, 2012
The afr goes to 12.5 right past the 60' and stays the same all the way to the end. I am trying to figure out how to put a video up
NytroMisfit
- Feb 18, 2015
- Levant, Maine
- 2009 nytro xtx
Dumb thought. There are threads on here about apex's having bogging issues. Have you ever checked or tested your Throttle Position Sensor with a multimeter to make sure it was reading out the right voltage/resistance. I think 2006 model year had an issue with those.
vollender
- Jan 22, 2012
The only time it boggs is with auto tune hooked up. I unhooked it for a test run and we picked up our 2 tenths on the 60' and went back to running a 11.15 from a 11.23
NytroMisfit
- Feb 18, 2015
- Levant, Maine
- 2009 nytro xtx
Oh ok sorry I misunderstood I thought it was bogging when you got hot also.
NytroMisfit
- Feb 18, 2015
- Levant, Maine
- 2009 nytro xtx
You know it really sounds like you are suffering from the engine suffering from "heat sink" after multiple runs. what are you doing for staging in between runs to help the system cool down?
NytroMisfit
- Feb 18, 2015
- Levant, Maine
- 2009 nytro xtx
I have read drag threads about these apex engines. They like to hold heat and it is hard to get them cooled down for the next run.
