tmk50
slymax
Talked to them a little while back. it's not out yet but the RX1 version will be out soon. Give it a little time, I'm sure it will be good, especially for trail riders. I don't want any more weight in the nose of my Vector. JMHO
thunder lips
- Apr 9, 2004
i wonder what the cost is?
AIRWOLF
Guest
is there A WEB SITE FOR MPI ?
Mountaintech
banjo04414
Now that I might be interested in. sounds like the perfect set-up for trail and fooling around on a lake.
AIRWOLF
Guest
THANKS
slymax
I think they said $4595 US for a stage one kit for the RX1. There were some pictures on Snowest Forums, if I can find them I will poach them & repost them on here.
mmmkokanee
http://www.snowest.com/fusetalk/message ... did=159770
scroll down and there's some pics...looks sweet!!
$4495 stage one 220hp according to MPI
AIRWOLF
Guest
Ok were did they put the oil tank?????
slymax
True Blue
Remanifactured oil tank with 3% less capacity bolts right
back where original one goes.
TB
TB
It is on their website and their is an article in SnowTech.
I think it ha great potential but I also think they Stretch things a little.
It also apears that the only way to adjust boost is new pulleys.
Snow Fever
Just reading about this blower thing and my question is, what if you did the bigger head gasket like MC-xpress does? Would it be able to run pump gas at 10lbs like the Turbos? I know it would be less H.P. per pound of boost but their say less then 12lbs on 10lbs. If you could have 225-230hp with a blower on 10lbs on pump fuel it would be (To me) well worth looking into. I wanted to send them an e-mail and see if they have tried this but they have no e-mail address. This whole thing of mixing 50/50 race fuel doesn't work for me! VP 105 here for a 5 gallon can is like 50+ dollars (Ouch!!!) but if you could do the head gasket thing and it worked, this would be NASTY to ride with the throttle response you would have.
True Blue
Hey SnowFever,
They are saying you can run 92 pump gas only and achieve 180+ HP
if you don't want to mix 50/50 or straight race fuel.
TB
TB
