thetruck454
In the middle of doing all the bearings for the first time at 12k miles and the last one is the jackshaft bearing pressed in the frame/bulkhead. I knocked out the old bearing and it feels as tight as can be, but the new one rattles slightly when you shake it. Think I got a bad one?
RobX-1
- Coldwater, OH
Makes you wonder if the bearing was ever pre-greased as they will rattle without any grease. I'd almost be inclinded to every so gently lift up the seal and inspect unless you're able to return/exchange.
thetruck454
It's not a sealed bearing. The side to the bulkhead has a separate oil seal pressed in the housing and the side towards the chain case is open to get the chaincase oil on it.
RobX-1
- Coldwater, OH
My bad, I was thinking of the bearing on the other side; not one within the chain case. I would think if the bearing is OEM or equivalent with the same fit and tolerances, then maybe it is a bad one.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Could be the brand. I go with NTN on the important less accessible bearings. And I also always add more synthetic grease as they are usually cheap with the initial fill.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
OEM bearing should be a Koyo, although I have used plenty of NTN’s in that location over the years with no issues.
