You can pull them out easily enough, just make sure you don’t lose the black plastic washers located on each side of the roller itself after you remove the bolt, and then the pin. I would use some hot soapy water and a green scotchbrite bad to remove any unwanted oxidation, dirt, and belt dust. Not a bad idea to do the same thing with the flyweights and both sheaves as well.
