sprintcat
2009 nytro XTX . Going with the suggested setting in the book that came with the sled........... 0.980 1.180. I am thinking I will probably be closer to the 1.180. Just installed
The star kit , I talked to Robert and he said that's right about where I want to be . Any thoughts with guys with the star kit installed in the Nytro XTX ? Thanks if not I will just use the factory specs. ..
sprintcat
Put 22 lbs on the track and adjusted as per factory specs on the loose side , DAM that track seems tight . Real tight
