Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
That is NOT rebuildable Its a steel body cheapoI'm guessing this shock can't be rebuilt. Am I correct? Doesn't take much pressure to push it down. Does getting a new shock help with sag any? I just got heavier springs for it so those should help.
Deeppow16
- Oct 19, 2015
Ok thats what I had thought. What would be a good shock to put in there that won't break the bank?That is NOT rebuildable Its a steel body cheapo
A Fox from Carver or Hygear is going to be the least expensive.
Is this in a Nytro MTX?
Deeppow16
- Oct 19, 2015
Yes it is 2008Is this in a Nytro MTX?
Measure the fully extended shock length and closed length, then you can try a Fox Float or maybe the XTX shock would work.
Deeppow16
- Oct 19, 2015
Ok I'll look into tomorrow and see what I come up with!Measure the fully extended shock length and closed length, then you can try a Fox Float or maybe the XTX shock would work.
I might have a shock for you and then you can always have it set up to your liking.
Deeppow16
- Oct 19, 2015
Alright I'll take some measurements tomorrow and let you.I might have a shock for you and then you can always have it set up to your liking.
Deeppow16
- Oct 19, 2015
Ok so I took some measurements. Open the shock is 17" eye to eye. Closed its about 11.375" eye to eye.View attachment 120919 View attachment 120920
I will take a look and get back to you on Sunday.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have a few options here for you if still need something.
Have a new aftermarket steel body for $100. Also have a good used piggyback aluminum rebuildable with dampening adjustment for $250
I looked thru my stuff looks like I don't have what u need but Travis ( hibshmas25) posted and can take care of u.
Deeppow16
- Oct 19, 2015
Ok, Yeah I think I would just take the aftermarket steel body as I plan on selling after this winter so I don't want to put to much into the sled. How do I get a shock from you? Paypal?I have a few options here for you if still need something.
