super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Looked everywhere but no luck. Can I tip the sidewinder on it right (exhaust) side like my viper to install skid plate? Proper handlebar on bucket so it was more at a 45. Or I can just lift rear high enough to do it also. Best method?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Your ok to lay it over on its side.Looked everywhere but no luck. Can I tip the sidewinder on it right (exhaust) side like my viper to install skid plate? Proper handlebar on bucket so it was more at a 45. Or I can just lift rear high enough to do it also. Best method?
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
I use milk crates under the skiis, works well for changing oil as well
sab2022
How do you get it physically on its side? floor jack? I would think a chain fall/hoist/engine hoist is best?
Kuzzy
- Dec 6, 2020
- saskatchewan
2022 STX GT
2017 King Cat M9000
I just put 1 foot on the running board, grab the middle handlebar loop and pull them over. It's easier than you thinkHow do you get it physically on its side? floor jack? I would think a chain fall/hoist/engine hoist is best?
stgdz
- Mar 27, 2021
- Buffalo MN
At what point will oil leave the tank if you deleted the valve?
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Upside down
Snody
- Feb 14, 2019
- Chazy New York
- 2016 Prototype Viper LTX LE
2007 Apex RTX
No issues with laying the sled on its side to install skid plate. As stated above, I often use VP race gas cans to get my sled higher up in the air to work under it/change oil. Things that aren't easy on the lift a sled lift or the electric rafter hoist.
super1c
Moderator
- Apr 10, 2010
Thx guys skid plate installed. Wasn’t bad just typical of posts I read. Holes didn’t really line up with rivets to drill out. Followed directions to the t and plate screws provided were to small diameter for holes, had to go wider screws. Bellypan nuts and bolts were pretty easy. I thought exhaust side was easier then viper. Overall pretty happy!
