Haudy991
I got my phazer in my garage to get it ready for snow. I have stock skis and the steering is very darty and they are useless in the little powder riding i do. Will putting 6" doolys help that? Or do I really need to buck up and buy new skis?
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Skis will help, but try the Dooly's or some shaper bars.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Look up the thread that has "ski shimming" it's the cheapest and most effective way to eliminate any darting!! Even go to the Bergstrom carbide site and he has a full arcticle on how to do it... Good luckHaudy991 said:I got my phazer in my garage to get it ready for snow. I have stock skis and the steering is very darty and they are useless in the little powder riding i do. Will putting 6" doolys help that? Or do I really need to buck up and buy new skis?
Totalrecall
also check that your front end is tight.
ski spindles,
ball joints,
steering bushings
etc.
The slop in the steering will cause a darting like condition as well. The ski starts to turn before the handlebars do.
ski spindles,
ball joints,
steering bushings
etc.
dox06
- Mar 25, 2007
- Jackson, Michigan
- 17 SW XTX SE
17 G4 Gade 850
Phazer
Eliminated the darting on my wifes Phazer by shiming the skis and putting one 6 inch dual carbide on the right ski. Just the right ski, left the 6 inch single carbide on the left ski. no daring.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Shimming the skis and adjusting the toe out just may solve your darting problems. Along with making the steering, ball joint as tight as you can make it.
If you can turn the handle bars and feel a lot of slop then the skis will jump around that much before your hands can hold it steady.
I would start with shimming and checking the toe, very cheap just takes a little time. You could be surprised by how much darting it will take away, I know I was.
Lee Rivers
I put 4 inch duals on my 08 and have zero darting ... still pushes on the corners in the trails anybody have a tried fix before I blow cash on some pilots?
canoehead
- Jan 14, 2011
- NE, Alberta
Bergstrom Triple Point carbides or I use Shaper bars. Bergstrom are the best. Check this old thread out also.Lee Rivers said:I put 4 inch duals on my 08 and have zero darting ... still pushes on the corners in the trails anybody have a tried fix before I blow cash on some pilots?
www.ty4stroke.com/viewtopic.php?p=84201 ... bdad794ca0
- Nov 1, 2009
- 2009 Phazer RTX
You could try bringing the limiter strap tighter by a hole. This will put more weight on the skis.
ef x eh
woodys make an updated dual runner called the slim jim. these are probably the best and cheapest fix. cures darting and pushing in the corners. they come in 4 in, 6 in and 10 in. i bought the 6 in and have been totally impressed. gives the XP guys red faces trying to keep up.
Haudy991
I started disassembling the front end last night. There seems to be alot of slop in the front end but could not find anything wore. Is that how they are? I decided to go with 6" doolys and shim the skis like suggested.
canoehead
- Jan 14, 2011
- NE, Alberta
It's hard to detect but most of your play is in the steering mixer under the airbox. I ripped my wife's Phazer apart and didn't think anything was worn bad until I had that in my hand. Hopefully UP BUshman's fix will remedy it!!Haudy991 said:I started disassembling the front end last night. There seems to be alot of slop in the front end but could not find anything wore. Is that how they are? I decided to go with 6" doolys and shim the skis like suggested.
Lee Rivers
Thanks for the info on the SLIM JIMS...when I bought the 4" I was told the 6 " would be to grabby in the corners .. should have joined TY 4 STROKE when I bought my sled..
Haudy991
I must have missed it. What is UP Bushmans fix?
- Nov 1, 2009
- 2009 Phazer RTX
- 6K
