moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
I am in the process of taking the subframe off my my 09 XTX and am not sure where to put jack stands or anything to support the motor that also won't get in the way.
Also I am going to be taking the track off possibly with the subframe removed still to balance points will need to account for this.
Thanks for your help! and pics are extremely appreciated!
Jeff
Jeff
bottlerocket
Every pic i have seen on here the sled is suspended from the top.
moab11
- Feb 4, 2010
- 2016 SKS 155
I know I have seen a pic or two of the sled supported from the bottom somewhere, but I can't seem to remember where.
Hanging it from the top could be done, but would be more work and not easy to move around the shop when needed.
bottlerocket
moab11
- Feb 4, 2010
- 2016 SKS 155
Alright, looks like in the pic, they also removed the engine brackets and are supporting the sled by the oil pan. but at lease it gives me a better idea of where I can place some stuff.
Does anyone else have any pics they can share or maybe some tips?
Jeff
Jeff
Bahr05
I had my subframe out and my sled was setting on the snowmobile lift. Here is a picture before i removed the subframe. The front cross bar is tight to the track and it seems very stable. I'm guessing the if you are removing the rear suspension as well, you would want to move the front support forward about 5" or so. This would allow you to still get the subframe out, while transfering some more weight to the rear of the sled, preventing it from becoming front heavy.[/img]
moab11
- Feb 4, 2010
- 2016 SKS 155
very nice, thank you?
May I ask where you got your sled lift from?
Jeff
Jeff
Mtnviper
Vendor
Slightly off-topic, just curious if anyone has weighed their stock sub-frame while its out?
Bill
Bill
macnytro
- Nov 24, 2008
i have one if you want me to put it on the scale
Mtnviper
Vendor
macnytro said:i have one if you want me to put it on the scale
macnytro, that would be great
Bill
Bahr05
I got the sled lift from Hyperformance Parts. It is made by American Manufacturing. If you look up eagle plows on the internet, you will find the manufacture's website. You might be able to order it factory direct. If you order the wheel kit like I did, make sure you get wheels that actually fit the brackets. I had to send the casters back.
Next, my stock subframe weighs about 21 pounds. Making one of them out of titanium would be sweet! Significant weight savings with added strength. I don't think paying $1000+ for one would be much fun though!
moab11
- Feb 4, 2010
- 2016 SKS 155
Thanks, I've been looking at getting one for a while now, seems like yours lifts the sled pretty high!
Bahr05
31" if I remember right. I really like it. Although I am going to have to make a drill attachment to raise the sled. The manual cranking to lift the sled gets old fast. I do like the wheel kit also. Then I can move the sled around while it is in pieces.
09nytro
sled lift is the only way if you are doin the track to
yamahaboy701
Sled lift works best, I used a little bit of a cheaper route:
By my 3rd subframe I found that you can use the old ones to hold up the front end too, this way I could change subframes right on the trail
