apexgt4life
2914 viper. Tearing down to do track. Have read numerous threads but cant really find a straight answer on what to do with top gear bushing. Gear appears to be over 100 dollars?
What are options.
Is there a spec for wear
6000 miles
What are options.
6000 miles
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Sad they haven't fixed the top gear bushing in 892 years...
ksiesel
- Mar 25, 2016
- Indiana
- 2015 Viper RTX-DX
- Indiana
I just did mine on my ‘15 after this season. It had just over 5k miles on it and was significantly looser than the replacement Super Bushing I pressed into it as a replacement. I purchased the replacement from Ebay. You will need a press to install this. I tried a pretty good size bench vise and it wasn’t happening.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
6000 miles is pretty good for the stock bushing.
There are a few different low-cost options to replace the bushing.
A search on this site will turn up 2 hours' worth of reading.
The bushing lasts much longer on the viper given it's about half the power of what most Winders are running.
I agree with others to just change it out with a better available option.
allyammies
Mine only lasted 4200 miles on my Viper. Change it check bearings too.
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
On a positive note we must still be snowmobiling.Sad they haven't fixed the top gear bushing in 892 years...
apexgt4life
Been reading for hours lol. Not seeing the options. Without modsThe bushing lasts much longer on the viper given it's about half the power of what most Winders are running.
tsiceman
Mcmaster Carr. 2867T67
apexgt4life
Is this the one i see on ebay fo like 30 bucksI just did mine on my ‘15 after this season. It had just over 5k miles on it and was significantly looser than the replacement Super Bushing I pressed into it as a replacement. I purchased the replacement from Ebay. You will need a press to install this. I tried a pretty good size bench vise and it wasn’t happening.
apexgt4life
Is this the ticket. No honing or anything?Mcmaster Carr. 2867T67
tsiceman
Yes it will need honed. Sandpaper on a socket till it fits, pretty easy!Is this the ticket. No honing or anything?
If you can press it in , you can easily hone it
apexgt4life
McMaster #60695k7Yes it will need honed. Sandpaper on a socket till it fits, pretty easy!
Found this in my reading from another post. Says same makeup as stock but has to be trimmed.
tsiceman
It will need honed to fit shaft also. We did not trim length at all on ours, just press flush to outside of gear like stock one wasMcMaster #60695k7
Both bushings are same size, I believe!
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
If we ride a conservative 1000 miles per year, and the bushing lasts about 4000 miles, we will have bought and replaced 223 bushings!On a positive note we must still be snowmobiling.
