sk-rx1
So Yamaha tells us the 1049cc motor in the Vector etc has new crank, rods, new castings.......... But why did they do it? More power, better mpg, lighter, revised mounting, or maybe just cheaper to produce???? Except for the new electronic throttle I have not seen anything.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
This is not true. Mr. Sled confirmed this in the "2016" thread.
sk-rx1
Sorry, not seeing any talk about engine internal changes.....
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
My apologies.....I gave you the wrong thread. Go here:
http://ty4stroke.com/threads/enough-bitchers-please-buy-a-cat-or-doo.134851/page-3
sk-rx1
Thanks, Still seems odd they could make this up. Maybe something for next year??????
Well... I have been miss informed on this...I guess there are some changes to the Vector Motor, It sounds like the motor will be around for awhile and they wanted to update a few things on the motor to make it more reliable for the future. I will keep you informed as I know more..
sk-rx1
Thanks. Maybe a little more power, better gas mileage, tighter tolerancing on clutch splines,and while I'm at maybe revised mounting features to place it lower in the Viper chassis. Maybe some day. LOL
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
From what I have been told the motor can not go lower because the exhaust pipe would be in the middle of the jack shaft. Its as low as it can go and keep the pipe angle and flow correct.
sk-rx1
That's true. But why can't they redesign the chain case and make it more vertical and maybe a little longer chain, run the pipes underneath the jackshaft. I understand the initial Viper project was to do it as fast and cheaply as possible, but we are ready for a Viper II. Some day there will be designs that do away with the jackshaft, not sure if we are there yet. A Yamaha chain case wouldn't be a bad thing.
yamariv
Can't understand why they would need to make it more reliable, that Vector that has 80 000 + miles can attest to that! Lol
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
All questions that you have to ask Arctic Cat. It is a Yamaha engine dropped into a Cat Chassis that was not designed for it. What you are asking for is Arctic Cat to redesign their chassis to fit one motor.
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
Maybe they do this to get rid of the noisy clutch rattle problem
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
According to CR's blog this morning, it was due to supplier agreements for engine components.
Sled Talk 3-9-15, "The internal changes to the Vector motor do not yield any change in its performance or durability. My understanding is the reason for the new parts (crank, rods etc) was due to suppliers and assembly. The engine design has not changed but some components are procured from different sources causing the updates. No big deal. The significant update is realized in the electronic throttle control (YCCT) – D-mode selective mapping and the Trailing Control for smooth operation" - See more at: http://snowmobiles.yamahablogs.ca/#sthash.xLgfD8rx.dpuf
This was Chris' response, so I think you can take that as gospel. No more guessing needed.
RobWarrior
Maybe I have been under a rock or something but I thought the Viper have the Nytro engine not the Vector? Isn't there slightly different internals in the two? If the Vip does have the Vector mill I'd be going Vector for sure.All questions that you have to ask Arctic Cat. It is a Yamaha engine dropped into a Cat Chassis that was not designed for it. What you are asking for is Arctic Cat to redesign their chassis to fit one motor.
My understanding is that its more Vector then Nytro..
