SRX Boy
I'm getting a code 85 on my '07 Phaser. I know the code relates to the oil pressure sensor and I did recently change the oil. Unfortuantely it was a couple months ago that I changed the oil - I can't recall whether you had to disconnect the oil presure sensor - did I forget to plug it back in??? I did run the machine for a good 5-8min right after I changed the oil and I didn't get a fault code - only got it this weekend when the kids went out for a ride. Any chance the fuse is gone, would be nice if that was the problem rather than having to go back under the air box.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
check the plug on top of the dipstick.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
I the plug on top wont throw a code, i think you will need to get under the air box again.
SRX Boy
Plug on dipstick is fine (would be nice if that was the problem) but as "yamahas" noted that won't cause the code. Anyone know if a blown fuse would trip the code?? Otherwise I'm back to tearing it apart again (at least it is wasier than getting to the Apex oil filter etc).
- Nov 1, 2009
- 2009 Phazer RTX
i guess that in theory a blown fuse could cause the same problem since no fuse and not pluged in could cause the computer to think it was broken since the circut is not complete.
worth a try.
worth a try.
SRX Boy
Thought that might be the case - anyone know which fuse is associated with the oil pressure switch, I can't seem to find it in the owners manual.
UpstateNY_sleds
I doubt it is a fuse. couldnt hurt to check though. Mine did that to me last year. I did an oil change and must not have plugged the sensor in all way. took a couple rides and it work itself out. same code.
- Nov 1, 2009
- 2009 Phazer RTX
UpstateNY_sleds said:I doubt it is a fuse. couldnt hurt to check though. Mine did that to me last year. I did an oil change and must not have plugged the sensor in all way. took a couple rides and it work itself out. same code.
agreed
Jeremy
It is prob. the little sensor beside the oil filter !!! Maybe nocked it loose or forgot to put it on or not put on all the way !!! You know the one that gets in the way of removing the oil filter !!!
ef x eh
i thought the sensor beside the oil filter was the knock sensor.
lholtzman
- Oct 17, 2009
Yeah, I just had my Yamaha dealer do an oil change on mine. Figured I'd save myself the trouble of doing it myself.
Two days later I have a code 85.
Do I really have to go diggin to find the oil pressure sensor beside the oil filter.
Guess i saved myself no time at all
Anyone have a good description of what I'm looking for
lholtzman
- Oct 17, 2009
Thanks, that's awesome. I'll let the dealer know. But I think after this I'll just sackup and change my oil. Can't be that hard. I guess I'll know after I go and find the sensor. Thanks everyone for the info. This website rules
- Nov 1, 2009
- 2009 Phazer RTX
lholtzman said:Thanks, that's awesome. I'll let the dealer know. But I think after this I'll just sackup and change my oil. Can't be that hard. I guess I'll know after I go and find the sensor. Thanks everyone for the info. This website rules
It is acctualy fairly easy to get to it. just remore your deadlight, upper plastics and airbox cover. then there are 3 rubber caps on the airbox, take them out and with a long allen key you can unscrew the air box from the sled and there you have it.
