herndonp
Does anyone have a 1.5 crossover track in there XTX with the tunnel protectors? Any issue with clearance on the front cooler? I was wondering if I could fit one in without any mods. Do you need to add extroverts or will it live with the stock drivers?
Thanks,
Pete
Thanks,
Pete
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I know the 1.5 will fit without any mods. If you get a fully clipped track I would put extros in, that way you can run a little looser. Just my 2 cents.
1975FA
I put a 1.5" track on my RTX and I had to remove the protectors off the front heat exchanger but not the top ones. I am not running any studs so it's not an issue.
canoehead
- Jan 14, 2011
- NE, Alberta
I believe the approach angles of the skids are different between an XTX and a RTXI put a 1.5" track on my RTX and I had to remove the protectors off the front heat exchanger but not the top ones. I am not running any studs so it's not an issue.
herndonp
So anyone out there with an XTX with a 1.5" crossover that has all the protectors in with no issues?
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
I took the front out of an xtx for a 1.352 cobra
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
The 1.5" will fit with all protectors,
I also recommend going with extroverts though as my 1.5" crossover would rachet w/ out them on my XTX
vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
no issues here
MNBlizzard
It will fit just fine with the protectors, but I'd take them out as it helps eliminate some ice build up. My bro ran the crossover for a couple seasons on stock drivers without any issue, no slipping.
herndonp
Thanks for the info guys.
Pete
Pete
stubb111
has anyone run this track studded??? I like the idea of a 1 1/2" track but also like running studs
RIGIDONE
I'm having a 129" 1.6 Ice Cobra installed as we speak, I was told I will be good to go on clearance..
herndonp
Let us know what you think of that track especially in the corners. Its snowing here in NH now.
Nytro Nasty
- Oct 17, 2014
- 2008 Yamaha FX Nytro 136, mountain fit vent kit, oft steering relocate, mountaintech skid plate, simmons flexi skiis with 6 dual runners, skinz front bumper, DDM Tuning HID lights, 55 watt ballasts with 4300k bulbs.
All done in one season.
That's is so far but much more on plate for this year!
Nytro Nasty
- Oct 17, 2014
That was the only pic I had. Track lug got cut off in picture a bit. Think is a 1.5? Not 1.25 but could be in between?
