grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I have the electronic version and can't read it. I stopped at the dealer and they have the same illegible version. Does anyone have one that's useful? I need some info on how the reverse actuator is wired.
Allen does. Some are in this post
http://www.ty4stroke.com/threads/viper-electrical-issues.139664/page-2
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I saw that post but can't read those either.
You tried printing the ones in service manual?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Yes, I printed the electronic version which can't be read. I was hoping someone had a paper version that could be copied with better resolution.
Yes call ULmER. I haven't had any luck either.
Hey I wonder if the Cat version is better? Will try tonight
It works! Looks to be same. Grizztracks you have a PM with link to 15 AC manual. Page 198 is 7000. I had no trouble zooming in on laptop. Its all legible.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
The Cat 7000 schematics appear to be the same and are legible.
Perfect! Will put this in FAQ sticky. Thanks Grizz!
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Janne339
This I don't understand? In schematic it's always power on coil and through the ISC relay to components? Is this really drawn right way?
Curtis Chambers
- Nov 19, 2014
- 2015 SRViper R-tx-Le
It is switched (controlled) with the negative. Brown/white ECU -. Have to follow that wire.
Janne339
That explain! Thanks!
