Anyone have a legable wire Schematic
grizztracks
Tech Advisor
Age
60
Scio, NY
FX Nytro RTX, RS Vector, SR Viper RTX SE
I have the electronic version and can't read it. I stopped at the dealer and they have the same illegible version. Does anyone have one that's useful? I need some info on how the reverse actuator is wired.
I saw that post but can't read those either.
Yes, I printed the electronic version which can't be read. I was hoping someone had a paper version that could be copied with better resolution.
It works! Looks to be same. Grizztracks you have a PM with link to 15 AC manual. Page 198 is 7000. I had no trouble zooming in on laptop. Its all legible.
The Cat 7000 schematics appear to be the same and are legible.
  • Heated Seat.pdf
  • ISC Relay Pwr Distribution.pdf
  • Viper Main Harness.pdf
  • Viper Handlebar and Console harness.pdf
  • Power distribution tail-fuel-headlight relays.pdf
here is another breakdown of the power distribution. Note that the so called tail light relay also powers the fuel injectors
It is switched (controlled) with the negative. Brown/white ECU -. Have to follow that wire.
