stgdz
- Mar 27, 2021
- Buffalo MN
But the caliper is locked to the driveshaft via the driveshaft saver. I can wobble the disc so.
acpantera
Maybe the shaft is still moving in and out of the bearing? I know I have had a brg saver on mine since day 1, the rotor looks scarred up were it mates with brg....How's that happening? Others have noted that as well.
acpantera
On another note BOP has brake pads, what are they like? Inexpensive too.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I would suggest that you take a good look at your driveshaft bearing and see it it wore the shaft down. If the driveshaft is moving around that may add to the heat.
The pads and rotor will get heat in them just from driving down the trail.
stgdz
- Mar 27, 2021
- Buffalo MN
Did the last time I had it apart, I couldn't see w lip and don't have a mic.I would suggest that you take a good look at your driveshaft bearing and see it it wore the shaft down. If the driveshaft is moving around that may add to the heat.
The back of the rotor did not have a lip on it either.
stgdz
- Mar 27, 2021
- Buffalo MN
Caliper was 110
Brake pads were about 125ish
Rotor was about 180-200
All in degree f
All in degree f
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Has anyone tried ceramic brake pads?Done it. All working well there and even was previously. Ordered up new stock brake pads today.
earthling
Not in a sled but ceramic pads take a lot of heat generally to work properly. Probably not for our cold environment.I don’t see pads for it. Assuming you use stock pads?
stgdz
- Mar 27, 2021
- Buffalo MN
