170plus
- Jan 14, 2004
- washburn maine
- 2021 polaris assault 850,18 sidewinder ltx,14 nitro xtx,06 apex rtx,
great post by the way rayman,cant get much clearer then you did ,didnt want to take away from this at all,im just saying we shouldnt have to do this to be able to ride
cawcislo
I'm glad someone is trying to fix an issue that Yamaha doesn't want to fix. Good post.
cawcislo
Anyone else do this to their sled?
yamahabandit
Replaced 4 stock idlers with 135mm doo wheels and added 2 extra doo wheels 1/2 towards rear of track. Absolutely no wear on slides after 200 miles in rather poor conditions. Did not machine or shim anything,just repaled wheels. Sled is 08 fx w/ 136 kit and 1 1/4 ripsaw. Last set of slides were toast in about 250 miles under better conditions.
enticeraised
parts
Hey my local dealer is having issues finding. Did you have CDN part numbers?
yamahabandit said:Replaced 4 stock idlers with 135mm doo wheels and added 2 extra doo wheels 1/2 towards rear of track. Absolutely no wear on slides after 200 miles in rather poor conditions. Did not machine or shim anything,just repaled wheels. Sled is 08 fx w/ 136 kit and 1 1/4 ripsaw. Last set of slides were toast in about 250 miles under better conditions.
maniac
I ran 4000 km with only very minimal slide left it seems like what someone else said they burn down quick and then stop looks scary but its amazing how long you can still ride with them almost done i really think alot of people are changing them too early just like i did
cawcislo
Where did you add the 2 extra wheels exactly? What kind of mounts did you use for those 2 wheels (the doo mounts mentioned in this post)? Are they doo wheels or Poo wheels. I see Polaris 135mm in this post. Or are the POO and DOO wheels the same SHI* (no pun intended).
sleddingfarmer
polaris wheels or ski-doo wheels, as long as they are 135mm it doesn't matter which wheel you use.
Grimm
cawcislo said:Anyone else do this to their sled?
I did the wheel mod on my Nytro last spring and 1700km later, the sliders are still in great shape, as are the wheels and rails. Quite the contrast to last year burning through 3 sets of sliders with the same mileage, and this year we have less snow and more ice.
mytro
SkiDoo has a 135mm with the 6004 and 6205 bearing I'm guessing the 6205 with the 25mm bore is correct and will fit the Yamaha brackets. You just have to check the offset for your lugs..?
Black 04-2135-20 Kimpex
Grimm
mytro said:SkiDoo has a 135mm with the 6004 and 6205 bearing I'm guessing the 6205 with the 25mm bore is correct and will fit the Yamaha brackets. You just have to check the offset for your lugs..?
Correct, it's not much of a concern if you were mounting these wheels on the outside of the rails. It's when you mount the idlers between the rails that machining of the mounts is necessary.
mytro
Grimm said:mytro said:SkiDoo has a 135mm with the 6004 and 6205 bearing I'm guessing the 6205 with the 25mm bore is correct and will fit the Yamaha brackets. You just have to check the offset for your lugs..?
Thanks, I want to go on the inside so I will have to have a look at them, are the Polaris wheels any closer on the offset?
Grimm
Using Skidoo wheel supports that accept the wider 6205 bearing will keep the idler wheel centered between the inner track lugs.
alsops
- Feb 17, 2009
- Headingley, Manitoba, Canada
- liverpool.com
- 2009 Nytro XTX
2021 Sidewinder XTX LE
sliders
I was changing them too early.
They burn down very quick and then stay at the min line.
Use 10mm wrench as guide if less hope you are in your drive.
Also, condition them on the first run...ride hard pack and heat them up, then get in powder and pack them to condition.
Got 3500km on last set and not great snow.
mytro
Grimm said:Using Skidoo wheel supports that accept the wider 6205 bearing will keep the idler wheel centered between the inner track lugs.
So inside:
Skidoo supports and Skidoo wheels?
Or
Skidoo supports and Poo wheel?
or
Are both the same?
It would be a shame for Yamaha to make a 135mm wheel, I'm guessing you guys are going with the Ski doo and Poo wheels because they will take beating unlike the aftermarket wheels..
Thanks again...
