Yamaha_Racer
Need some info help on apex se has 5000 miles, replaced starter motor, solenoid, all the fuses and relays, just won't start, backfires then pops
earthling
no codes?
Thats a typical sign of a stator or pickup coil going out but usually there is a code (12) to go with it.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Did you change the plugs too?
Yamaha_Racer
No codes on podno codes?
Yamaha_Racer
Changed plugs and oil same issue backfires then popsDid you change the plugs too?
RAMSOMAIR
Exhaust donuts?
earthling
I had a problem a few years ago where the sled would turn over, it would catch, backfire, pop etc but would not start. This eliminates fuel, air, spark as even a backfire requires all of those, so you should just be down to timing. The problem I had was the stator was toast.
Yamaha_Racer
Going to try change stator hopefully that will change everything n fire upI had a problem a few years ago where the sled would turn over, it would catch, backfire, pop etc but would not start. This eliminates fuel, air, spark as even a backfire requires all of those, so you should just be down to timing. The problem I had was the stator was toast.
Yamaha_Racer
Would that cause it to not start at all?Exhaust donuts?
