Sly99
any one know where that bolt and nut go on the sled?
Did you check on the back of the turbo mount? There are 3 bolts like that.
no1b4me
Did you take a close look at the bolt threads to see if they were even used?
Could have been dropped during assembly line operations, darn I found a spare gas cap wedge in between the tank and tunnel right side up against the exhaust heat shield..... Now have a spare cap.....
Actually I dont think that bolt is big enough for that base on your image.
Sly99
All 3 bolt under the turbo it's thereActually I dont think that bolt is big enough for that base on your image.
Sly99
Likely kit, was not there last year when I did my maintenance. Sled have over 10000kmDid you take a close look at the bolt threads to see if they were even used?
Pstn head
Maybe the steering post supports, up by the handle bar riser?
Looks like it come from the Skidoo pyramid frame.....I mean Yamaha.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I second the comment about the pyramidal frame. Check all those joints. They flex alot and am surprised each year how many need to be snugged up.
MS
MS
Sly99
You are right it's was near the steering post. Thanks guys !!
