justinator
No trouble backing up. Fwd to about the 40 second mark and you can see how they work.Do these work well when backing up?
KillerBee
- Jan 1, 2010
- Waukesha WI
- 2018 Sidewinder LTX LE 50th
The spring pressure downward is significant and after two seasons with them have never had a problem. I make every effort to pull them up before backing.Those scare me. I've seen them get bent and tangled in a track, ripping inside lugs right off.
Not sure how they could get tangled in the track… Unless they were down and went airborne and landed on one side or the other, not flat?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
This may have happened . It was ugly. Ruined the trackUnless they were down and went airborne and landed on one side or the other, not flat?
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Been running these for 3 years now and no problems.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
where did get those?View attachment 163587
SledFreak
- Feb 7, 2005
- Ontario. Canada
ya what Stain said!!
SideHogger
- Apr 16, 2016
- upstate ny
Dennis Kirk is selling them now. RT PRO scratchers. Now called Cool n Lubeya what Stain said!!
Turboflash
- Mar 18, 2019
- Southern MN
What happens when they wear end off?
SideHogger
- Apr 16, 2016
- upstate ny
Get replacement rods. You can also change amount of pressure to the snow.
wwolfe68
- Jan 16, 2015
- Livonia, NY
- 2021 Yamaha Wolverine RMAX 1000 LE
2020 Yamaha Sidewinder LTX-GT
2014 Yamaha Vector LTX
I mounted mine to skis on inside so throws snow onto track. Had them on for 1 season and used few times and worked . Bought kit from barn of.parts and mounted them on front based on there recommendations
fourbarrel
Building a collection one sled at a time
Any issue with the spot on the running board cracking from the stress of the cable flexing all the time? Can I get a close up pic of how and where you mounted yours?Mounted mine under footwell. I did not want them banging track and skid. I mounted to where they swing in front of track. Works well for reverse and they tuck into the running board when not down. Rode on hard ice and did a great job on both hyfax and engine temps.
View attachment 163461View attachment 163463View attachment 163462View attachment 163464
mr. bwok
- Nov 22, 2016
- toronto
- 2017 sr viper ltx
- Marmora
Let me see if i can find a better pic for you. It is on the outside of the footbed where there is lots of bracing. Zero issues with flexAny issue with the spot on the running board cracking from the stress of the cable flexing all the time? Can I get a close up pic of how and where you mounted yours?
HABS 1
- Oct 22, 2015
- corunna,ontario
- 2006 apex gt,136 Hartman ext,dalton clutched,full excel exhaust,yamiheaters,cna pro ex white skis,hid lights,mtx riser,1.5 intense track,etc,etc!---2021 sidewinder xtx se
what kind r those? it looks like it has a keeper for it while not in use, i have stock ones that the sled came with on and i dont like how they clip around skid rail while not in use, looks like will eventually wear paint off, has anyone installed a keeper fir lack of a better word?I use these. Never had good luck with cable type scratchers. Ends loosen up, and or rail connection loosens up and not enough pressure maintained downward. View attachment 163542
RobX-1
- Coldwater, OH
Could always do something like this when not being used
