Silver4
- Oct 29, 2020
- Ottawa
- 2013 RST90D Venture 973 cc carbs
Shocked in the manual to read that a normal (car) battery charger can not be used with my 2013 RS venture sled. Is this true???
Confused
- Oct 12, 2008
- Mound, MN
- '21 Sidewinder LTX SE
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
I would say no, but will also say you should not charge at a high rate either.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
No! Usually use any charger at a 2 amp trickle on all my toys. However, need special charger for lithium batteries.
any charger that you can lock it into a 2 amp or maintainer charge level would be ok for a sled battery. i use a 2-3 amp charger all the time on everything i own. only haul the big one out when the battery is stone dead in the truck or car and the boost pack is run down.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Lower the amps, the better. 2A is the best for these small batteries.
20/80
My Yamaha dealer told me that the very first charge on the factory battery for Yamaha which is Yuasa needs to be put on a very low amp charger, he had to buy this type of charger for the batteries that are in the Yamaha machines he sells, simply just using a basic 2 amp trickle charger found at your local automotive store will charge your Yuasa battery but you will not get the full life and charge out of your battery, that is why it states that in your manual, I have got close to 10 years out of a Yuasa battery in my Atv which I use for plowing, I did alot of winching when using the plow over the years, so if it was a lie to me its a lie to you.
