rock
gregs30, I thought of that as well. I asked around and found that the important thing to do is get the 55/60 watt match to the stockers. These match and I've been nothing but pleased.
gregs30
Sounds great, thanks for the info!
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
'Dog,
Don't go taking offense...........it wasn't directed at you.......or anybody in particular. Just an observation that people sometimes put emphasis on minute parts while blithely ignoring the overall picture. Just expressing an opinion. Everybody has to make their own spending choices. If you don't think they're worth it to you..........then they're not!
Peace!
Peace!
Fast_Eddy
I ordered those Euro Dezigns H.I.D lights for 9.99 off ebay and i love them.they have a blue look to them that really stands out from all the other sleds out there.Better at night the stock to.
BA APEX
caught a good deal($25) on ebay back end of November. bulbs are definately nicer than stock but the stock is no slouch.
the overlapping(or lack of) between hi & low beam does not change with the silverstar.
easiest way now is walmart, watching ebay for a better deal sometimes drives you nuts if they are a popular item.
NY_Nytro
They are on Ebay constantly, typically a pair go for about $15 - $20 + $5 shipping. The seller is "go4bestdeal"
AIRWOLF
Guest
I have them in my Apex
WELL WORTH THE MONEY !!!!
stinx
what is the part number for these? I am assuming the Attak uses the same bulbs
Yes put them in my RX1 thye ROCK!
Skydog
Skydog
ridesrx
gregs30
Did your buddy's truck have daytime running lamps? I believe I read once that some of these bulbs aren't recommened for all day use. Not sure if that's the case for all of them, but it's the reason I haven't put them in my Yukon.
iasledder
I don't know about the 9003, maby it fits and works. Normally I believe it should be a H4 with a PT43 base.
buddah
- Apr 14, 2003
- Wetmore, MI
ridesrx said:I believe I read once that some of these bulbs aren't recommened for all day use. Not sure if that's the case for all of them, but it's the reason I haven't put them in my Yukon.
ridesrx,
I've had them in my SUburban for at least 2 years WITH the daytime running lights and no failures or any other issues.
byoffcr
Now for the draw back to watch for is at around 3000 miles the alt . seems to weaken a little on the apexs.. and the sled will miss or flutter slightly in mid range do to the amps being drawn with these bulbs.. Rebuild the alt. and its all ok. I have these in all my sleds and it is cheap way to increasa your safty. Lots safer at night.. Not sure if it will affect all apexs but if it happens you will know what to look for. byoffcr
- 146K
- 33K
