weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Got a mail from OFT today and in that mail they said that the Nytro ROV tether fits the Phazer just fine. So I am probably go with the OFT kit for the Phazer. I like the tether that you recive with that kit.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Took off the upper ball joints yesterday and put them in the lathe and shaved off 4 mm on each side.
When I come home today I will mount them on the sled and go out and try it.
See what happens with the handeling.
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
I bought floats 3's last season for my 07. I just sold them. Could not dial them in. Up the pressure and still severely rolled into corners. Hopefully the guy in Rimbey AB who bought them enjoys. Had there been an option for "Elkas" for my 07 I would have purchased those. Now I learn elkas are available. I've run on my race quads and will never buy another kind of shock. May be something you may want to look at as an option.What ski shocks should I get?
I have found two different one to chose from. One is Engans and the other one is Fox Float 3. It's about the same price for them both, so that is not a deal breaker.
Any suggestions?
Float 3's weigh just over 2lbs.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
I would like a suspension with compression adjusting at least and not just the spring pretension. So Elka have a suspension for the Phazer MTX?
Yesterday I pushed the trottle to the max to see what RPM I landed on after my clutch tuning I made during the summer.
Landed on 11800 rpm on really hard packed, so I will probably land in the sweet spot of the power range in more deeper conditions.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Looks like I'm tradeing the Phazer for a 4 stroke Yamaha Viking. More use for a work sled to pull stuff.
ATV PRO #11
- Jan 22, 2011
Different machine, same blood line. Yamaha!!Looks like I'm tradeing the Phazer for a 4 stroke Yamaha Viking. More use for a work sled to pull stuff.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
So, no new posts for me in this thread. Traded the Phazer for a Yamaha Grizzly ATV today. Hopefully the new owner will enjoy the Phazer!
mtuyamaha
- Nov 2, 2016
- Houghton, Michigan
- 2007 Yamaha Phazer MTX 151
81' enticer 300 twin special
75' Scorpion 440 Whip
Where did you find those bolts for the sway bars? Do you happen to remember? It would help me out greatly!Now I'm probably done fixing all the errors the local Yamaha store made on my sled.
Done with the sway bar disconnect thing now and will try it out this winter.
I think I can go from connected to disconnected in about 30 seconds.
and how it looks while disconnected from the A arms.
I'm also thinking of making a cargo rack on the back of the tunnel or I will go with the Rotopax system just to bring with me fuel. But they are expensive here in Sweden, about 160 USD for the 1 gallon gasoline pack.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
The ones with the looking pin thru the end of the bolt? I drilled them my self. Just ordinary bolts with a hole.Where did you find those bolts for the sway bars? Do you happen to remember? It would help me out greatly!
mtuyamaha
- Nov 2, 2016
Oh really? Could you not find anything like that or did you do that just because you could?The ones with the looking pin thru the end of the bolt? I drilled them my self. Just ordinary bolts with a hole.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
I did not think of anything else. Had everything done in two minutes.Oh really? Could you not find anything like that or did you do that just because you could?
