Nice Rumble
Is this for a 12V DC accessory port? Is there a connector all ready wired for this?
Will this fit? It's from the Venture GT.
http://www.yamaha-motor.com/sport/produ ... etail.aspx
Eagle1
yes, but nytros aren't pre-wired so you have to cut the connector and wire it in, at least that's what my dealer told me. I bought one but haven't gotten around to it yet.Probably wire right to the battery
Daranello
Suspended
good place to hide a spare key!!!
LJ 452
It was my understanding that the Nytro's were all prewired. At least for 09'. I asked when I ordered as the spec shows the 12V acess. as being optional. I said do I need to request it have the plug and they said no, just order the plug from the acess. Well I've got it and the sled, I'll be finding out tonight. Let you know.
Gibby
i ordered a acc. outlet for a rage or vector and it plugged right. 09 XTX
marsh14
My xtx had the 12v plug in it when I picked it up. I ordered it that way.
Throttle Jockey
08's were not prewired, BUT 09's are prewired for the accesory plug, just get a plug if you want one and hook it up and you're good to go. just plug it in to the white connector (pigtail) kinda below that opening.
PS2003
just did mine yesterday. The whole kit is available from the dealer. and the mating plug is right below it by the frame. no cutting of wires or anything. 10 minute job and you got a 12v power sorce. kit was like 45.00 and the 12v plug in converter so I can plug in my heated shield was 24.99. kind of spendy but a very neat clean install so who cares.
Eagle1
so much for 10 min job. mounted in the hole plugged into white connector (took off white cap) plugged in and no power at the plug
even turned sled on nothing. tried plugging it in couple more times nothing. any ideas? is the plug hot all the time ?
PS2003
you started it? I had to start mine to have 12v there? Key on engine off it had nothing? Just asking?
2008 Nytro RTX
I was wondering the same thing because my sled has it,But now I know =) lol
Eagle1
yea started it nothing. I even tested the plug with the led on it in the truck and it worked
PS2003
sounds like a fused circuit that has no fuse or a bad fuse? I need to get to the dealer and pick up my service manual so I could check for ya.
Eagle1
fixed!!!
It was bad fuse. small black box located right under reverse handle.
plug works now thanks for the help ps2003
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
Anyone have a supplier for the white oem plugs?
