Heritage
Anybody else think this might work??? Replace the two
side by side shocks with one big air shock (megaflloat)??
If not...wouldnt it be cool if yami made a plastic mono with a megafloat?
Super Sled
- Feb 25, 2009
- Summit X
I really like the idea of a composite Mono shock suspension. It would be stronger, lighter, and more durable than the current steel arms No need for the beef up kit or pc then, of course.
I'm assuming you'd have to stick with the aluminum rails tho.....
Heritage
No you wouldnt...check out the zx2..plastic rails too.Super Sled said:I really like the idea of a composite Mono shock suspension. It would be stronger, lighter, and more durable than the current steel arms No need for the beef up kit or pc then, of course.
The weight savings alone is worth it.
Super Sled
- Feb 25, 2009
- Summit X
Someone should market this!!!!
kinger
You can already replace the ZX2 shocks with floats, the CtC lines up well with some standard fox shocks. Problem is the shocks probably wont hold up being designed for front suspension in the rear.
They would save about 6lbs so not worth it to me when the ZX2 works sood.
Ditch the mono and get the ZX2 and you will forgot all about the mono.
Super Sled
- Feb 25, 2009
- Summit X
Your prob right, Mr Kinger. The ZX2 sounds really good. But Ive never set back a suspension/ retro fitted another skid into a sled and wouldn't know how...
So I'll keep working to improve the mono!
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I don't like that shock, seen 3 of them go bad this year. They need more protection.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Super Sled said:Your prob right, Mr Kinger. The ZX2 sounds really good. But Ive never set back a suspension/ retro fitted another skid into a sled and wouldn't know how...
I didn't know how when I did my ZX2 either. Very simple job as it comes with the templates. Kind of a plug and play deal.
KevinS
Sasquatch said:Super Sled said:Your prob right, Mr Kinger. The ZX2 sounds really good. But Ive never set back a suspension/ retro fitted another skid into a sled and wouldn't know how...
x2. When I did my ZX2 I was surprised at how easy it really was.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
How have them ZX2's held up. Do you guys ride hard for mostly groom trails.
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Hard to break em! 8.000 miles on mine and I've pounded the heck out of it.
- Jun 28, 2004
- Clinton, Wi.
Anyone who can read a measuring device and drill some holes can do an aftermarket or retro another brands skid. Patience and double checking layout is the key! I've done 4 swaps now and each is easier than the last. A good square, centerpunch, sharp drills and an air riveter are the most basic set of tools you'll need. AND, ya' got the TY gurus to ask questions of while you're working on it !!
Super Sled
- Feb 25, 2009
- Summit X
Is it really that easy?
KevinS
Super Sled said:Sasquatch said:Super Sled said:Your prob right, Mr Kinger. The ZX2 sounds really good. But Ive never set back a suspension/ retro fitted another skid into a sled and wouldn't know how...
Yep. The mounting plates have predrilled holes for the rivets and mount holes. They also have holes that line up with the stock mounting holes. Using the stock mounting holes and some bolts that they supply you bolt the mount plate inside the tunnel. Then using the rivet and mount holes in the mountinbg plate as a guide you drill them thru the tunnel. Once all the holes are drilled you rivet it all together. After that you just remove the bolts that you installed in the first step and mount your new skid.
Super Sled
- Feb 25, 2009
- Summit X
Dang. Thx for the explanation Kevin S. That doesn't sound so bad, even for a weekend rookie mech like myself.
