APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
I'm just wondering how you remove the 2 large upper wheels in the rear suspension of a 2011 Apex. I have read about Sidewinder's. I'm just wondering if there is an easy way for the Apex. I know Travis at Barn of Parts has a tool for a Sidewinder but he has told me it will not work for the Apex. Also, bearing number would be great. Someone has told me they are 6205's
theCATman
Raise rear or entirely lift,l the sled, remove bolts, skid drops, ( impact works good because the other side/shaft likes to spin), loosen allen head lock/set screws on the collar they are on, and pull them off.
APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
Ok great! Suspension is out of my sled. So just get that lock collar loose and the wheels pull right off? I did loosen the allen head screw and the collar seems to be stuck. I will work on it. Thanks for the info
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
screw the bolt back into the shaft and hit bolt with dead blow hammer to drive shaft thru.
APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
Your suggestion worked perfect! Took a few minutes to change both bearings. Thanks alot!
APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
