Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
- 2016 Polaris iqr 600
2013 nytro mtx 153 supercharged 180.
2012 yamaha nytro xtx (burned)
2009 polaris iqr 600(burned)
im looking to make my nytro light as possible. The only mods I have right now are air frame running boards and mountain tech a-arms. I heard somewhere guys are taking the reverse off there nytro to save weight. Anything would help . I think I'm going to try to delete the park brake and take the cooling fins off the brake rotor. any help is appreciated. I have a 2013 nytro mtx 153 mpi supercharged. Pretty much stock besides what I mentioned.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Toss the oem batter and get EarthX battery. That saves 12lbs right there.
MS
MS
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Double yupToss the oem batter and get EarthX battery. That saves 12lbs right there.
MS
Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
Thanks!
12meter joe
When you replaced the battery did you notice any unbalance in the way it handled? That's a lot to take off of one side.
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
I changed my battery to a lightweight battery and can't say i noticed any unbalance, i also have removed the parking brake and the fins on the rotor.
I have a Shorai LFX18L1-BS12 Lithium-Iron Phosphate (LiFePO4) PowerSports Battery if you are interested. It is only 2.3 lbs. I'll ship it to you for $50.
RIGIDONE
canoehead
- Jan 14, 2011
- NE, Alberta
Just changing to an aftermarket can will reduce up to 12lbs.
Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
Thanks guys I will be putting the skinz under tunnel exhaust and seat this summer. I'll also be getting the earthx battery, and a few other things to lighten her up. I'm still looking to see if I can take my reverse off to shave a few pounds.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Yes you can remove reverse
Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
Thanks. By any chance do you know how to go about it .
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Not positive. Requires diff gear(s?) and some other bits and pieces. Someone on here may. My dealer knows how to do it
Alphadog
- Mar 6, 2015
- Appin Ontario
- 2018 Sidewinder
Definitely the Earth-X Lithium battery sheds off 10-12 pounds and better cold cranking amps for Cold Northern mornings.
Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
Thanks.
