junior_234
- Feb 28, 2013
- Stevens Point, WI
- 2014 Yamaha Nytro XTX 1.75 Push Turbo
I have a 14 turbo Nytro XTX 1.75 and the tuner skis are great. No need to swap them out. Put on a vent kit and get that hot air out from underneath that hood. When you ride with the supercharger you will notice an increase of heat pouring out of the handlebar area.
junior_234
- Feb 28, 2013
- Stevens Point, WI
Correct me if Im wrong here but dont the late model Nytro's have larger idlers as stock oem equipment and don't require upgrading??[/quote]
Negative. Even the 2014 Nytro's have the 129mm wheels. I measured them with a caliper. I upgraded with the excell wheel kit. They are the 135mm wheels. The difference of 6mm doesn't stress the rails at all.
I highly encourage anyone to upgrade if you are going to stay with stock slides.
MNBlizzard
Studding an 1.75" track? Don't do it! Take the track off and install an ice ripper if you really want studs. I think you should look into a good set of gauges for the supercharger, I'm going to give the koso x2 a try as it looks to fit my vision the best.
grumpysanta
excell wheels are a must even on 2013 and 14
fubar8182
- Nov 5, 2014
- 02 viper / 13 nytro txt 1.75
I have a 2013 xtx 1.75
Supercharger mpi stage 1
Tunnel block off plate
HIDs
Medium winshield
Rotopax rear fuel 2 gallon can
Front and rear storage
JRE skid relocator
I was thinking of skinz airframe boards
HIDs
Medium winshield
JRE skid relocator
Bpatch50
Instead of the trail tank I recommend getting an external fuel setup like the two small yamaha tanks that go at the rear of the running boards.
My reason for this is so you can carry 'good' fuel. I have the mpi as well and I'm always nervous about the quality of fuel that's actually going into my tank. Now I can fill up my other tanks with race fuel or at least 100 pump gas and mix in a couple gallons. Cheap piece of mind.
twiz28
- Nov 8, 2004
- New Brunswick, CAN
- 2017 Sidewinder BTX 1.75 Backcountry
2017 Sidewinder XTX 137
x2 on the mountaintech skid plate, saved my #*$&@ more than once, steering re-locate is a sweet addition as well.
Broue
- Feb 28, 2015
- FX Nytro XTX 2009,
Factory race front end
Star suspension relocation kit and revalve
Ski Doo #503192064 center spring
135 mm idler wheels
Oilite bushings
Grizz steering relocator
Tuner ski : 6 ''carbides,
WRP seat
Vector gauge
Custom Taillight
LinQ tank
Sno Sport 1990
Ski Doo Tundra R 1998
1-WRP seat for better ergo
2-Rear Suspension mods (star suspension and revalve)
3-Front end mods (mountain tech A arm)
Enjoy!
Enjoy!
fubar8182
- Nov 5, 2014
100% I am doing the revalve. I don't think the seat is that bad. Going to go for the barker exhaust also and prob vector gauges. I have SC in whatever I can do to help that. I want to wipe all doos out1-WRP seat for better ergo
Enjoy!
jason22
- Feb 28, 2014
- Newboro Ontario Canada
- Yamaha Nytro
Hi guys, I also have the same sled bought it at beginning of march. And was wondering what to add on aswell.
here's a list of stuff on sled already.
MPI Supercharger
Gems management system (not sure what its for. has plus and minus adjustments and mode button on it)
HID headlights
ARS FX front end.
MBRP Standard can
ice scratchers
Handle bar risers.
Now I've heard alot about a tunnel block off plate. What is purpose of the plate and is it a direct bolt on and wheres best place to
buy one? (I'm in Kingston Ontario
Any help would much be appreciated
Thanks in advance
Jason
MPI Supercharger
HID headlights
ARS FX front end.
MBRP Standard can
ice scratchers
Handle bar risers.
Thanks in advance
Jason
fubar8182
- Nov 5, 2014
What's up? It prevents the snow of building up underneath ur tunnel. Otherwise the snow will pile up and none would get to the heat exchanger and would overheat. I over heated once got the plate and never again. Its riveted in. A few companies make them it's been a few yrs now I forgot what company. But just search nytro threads or Google tunnel block off plate nytro it will show.(old forge ny-Saint Alexis qc)Hi guys, I also have the same sled bought it at beginning of march. And was wondering what to add on aswell.
MPI Supercharger
HID headlights
ARS FX front end.
MBRP Standard can
ice scratchers
Handle bar risers.
Thanks in advance
Jason
sprintcat
fubar8182
- Nov 5, 2014
GreatLike this ,I had a buddy bend it up, I text him the measurement, and he had it tooo me after work .
jason22
- Feb 28, 2014
- Yamaha Nytro
Thats cool. now I'm guessing this keeps all the snow off the exhaust system?
kurzy
- Mar 25, 2011
- Peterborough On, Can.
- '08 40th. Anniversary Nytro RTX
It does keep the snow off the exhaust but still allows lots of air up there to cool the pipes. It's a good mod that's really cheap. Stops a lot of the ice buildup that occurs in the tunnel. 1or 2 pounds if aluminum saves you from carrying 20-30 pounds of ice.
