Summer TECH Contest DIY Steering Bushings
APEX 06
Sheboygan, WI
Website
www.sheboyganyamaha.com
09 Nytro XTX, 08 Apex Mtx
I'm starting from having the gas tank, seat, head light pod and body parts off. FIRST STEP remove the wiring hardness out of the way. Then remove the two screws that hold on the white cap.
Step 3 removing the nuts that hold on the bushings. Bend the tabs back that hold the nut in place, then use a 12mm socket to remove the nuts.
Step 5 pull the first half of the bushing off. The metal sleeve's may pull out at the same time, put them off to the side to be cleaned and reused.(If Good)
Step 6 remove the bolts that hold the bushings from the back side/gas tank side.
Step 7 pull the bars forward(toward the ski's) to get the back half of the bushing out. There is a backing plate between the bushing and the delta box.
  • 7%20pull%20bar%20forward%20to%20get%20back%20part%20of%20buhing%20out%20set%207.jpg
Step 8 use 1500-2000 sand paper to clean up the shaft.
  • 8%20use%201500-2000%20sand%20paper%20to%20clean%20up%20the%20shaft.%20set%208.jpg
Step 9 grease the bushing(use a low temp grease), grease the shaft. Then push the back half of the new bushing and backing plate in by pushing the bars toward the ski's. Then put the metal sleeve's back in the bushing after they are cleaned.
  • 10%20push%20the%20new%20one%20back%20in%20with%20the%20backing%20plate.%20set%2010.jpg
Step 13 the lower upper bushing's nuts are behind the wires and the nuts have black rubber caps on them to protect the wires. You will have to move the wires out of the way to get to the nuts. After that everything is the same as the one before. Just everything is toward the gas tank.
Step 14 there is a nylon bushing here, replace it. You have to take this plate off and leave it off till you are done with the lower bushing. The bolts that hold on this plate are one 14mm and two 12mm.
Step 15 ok this one sucks you have to remove the air box and undo the oil tank so you can move the shaft to get the back half bushing out. When finish with this one go back and bolt the plate back on that you took off in step 14. That's it when doing this I would check your donut and change your plugs(if needed). Total cost for the stock bushings was 22.00 bucks from Sheboygan Yamaha.
