yukonranger
Hello, I need to find out what the resistance should be for the throttle position sensor at closed and open throttle. If anyone has a shop manual or knows how to set the throttle position sensor, that would be awesome
yukonranger
re
Cool, man thanks I would like to know how to adjust the tps as well if you have that info.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You can check the position in the diagnostic mode as well in the gauge cluster to see if the sensor is bad or out of adjustment. If memory serves me right it should be 14-18 at closed and 94-100 at wide open (this means throttle position).
yukonranger
Thanks for the help guys, I got it set tonight. I can't believe all the cool #*$&@ that you can see in the diagnostic mode
Cool!I need to check that out myself.Thanks SRX!
RedPhazer
Hi Guys,
Just curious here... Is this something you are checking for optimal engine performance? Or, was the engine not running right and you are troubleshooting?
Thanks,
Tom
Thanks,
Tom
yukonranger
No I took my tps off and needed to set it when I put it back on.
No noticeable issue with mine but things do change with time.Cant hurt to check it.On our Cannondales min and max TPS settings are easily set and often they are off by a hair.Runs much better after a throttle cal.
