Nattydread
I have read in Snow Tech that some are recommending the Ulitmax belt vs. the OEM yami belt, has anyone done it and have some feedback? I get slippage (squealing) with my stock belt currently when my 06 Nytro warms up...
stock belts are the best period!!!
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
The reason is the yamaha belts are a harder compound for durability and long life, downfall is they do tend to slip, dayco or carlisle belts are a softer compound than stock which means they do not slip. Snowtech has tested this and says this is a good upgrade. I keep the yammie belt for a spare. I always run ultimax belts. One thing I find is the Carlisle ultimax 3 is way over priced compared to the Dayco HPX. About thirty dollars more. I have never broken one on my SXR.
I run yami belts on my warrior... they squeel like a sob when new, but I have no problems with them.
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I run the Ultimax XS belt and love it. The stock one will certainly last forever. But the performance from the Ultimax is much better. Less heat and less slipage.
I've current got about 2000 miles on the Ultimax. But I suspect that I will end up replacing sometime this winter. To me, the added performance is will worth the decrease in life. But I see a belt as a normal wear item - like carbides. I don't expect my belt to last forever.
Kevin Garceau
What type of added perf are you guys seeing?
I only notice mine slipping/squealing on deceleration
skyboz
gade-thrasher said:I run the Ultimax XS belt and love it. The stock one will certainly last forever. But the performance from the Ultimax is much better. Less heat and less slipage.
Does you lose some RPM's with this belt?
grumpysanta
BELTS
WASH NEW BELTS WITH HOT SOAPY WATER TO REMOVE FILM AND BREAK IN FOR AT LEAST 10 MILES EASY . IT WILL MAKE A DIFFERANCE
skyboz
Re: BELTS
I put my new belts in the dishwasher without soap before I put them on!!!
grumpysanta said:WASH NEW BELTS WITH HOT SOAPY WATER TO REMOVE FILM AND BREAK IN FOR AT LEAST 10 MILES EASY . IT WILL MAKE A DIFFERANCE
jim-bob
Good Lord!!!! You mean you were just sitting around one day and said to yourself " I wonder what would happen if I put this in the dishwasher" I mean It's probably a great idea but the drugs you were on had to be the best / just kidding / I'm constantly amazed at the ideas that come across this site / isn't it just the best / later / jim-bob
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I don't notice any loss of rpm. The performance gain I do notice is a better throttle response. I know this sounds weird ... because what does a belt have to do with the throttle? But what I mean is that when you nail the throttle, the track reacts faster. This is because the belt isn't slipping. And I've also switched from the stock to the Ultimax within the same day to see the results. By putting my hand on the clutch ... the Ultimax results in a cooler clutch than the stock.
grumpysanta
BELTS
COOLER IS WAY BETTER
skyboz
gade-thrasher said:I don't notice any loss of rpm. The performance gain I do notice is a better throttle response. I know this sounds weird ... because what does a belt have to do with the throttle? But what I mean is that when you nail the throttle, the track reacts faster. This is because the belt isn't slipping. And I've also switched from the stock to the Ultimax within the same day to see the results. By putting my hand on the clutch ... the Ultimax results in a cooler clutch than the stock.
skyboz
jim-bob said:Good Lord!!!! You mean you were just sitting around one day and said to yourself " I wonder what would happen if I put this in the dishwasher" I mean It's probably a great idea but the drugs you were on had to be the best / just kidding / I'm constantly amazed at the ideas that come across this site / isn't it just the best / later / jim-bob
Crazy ain't it!!!! I got the idea from a friend who owns a drag racing team! He's been successful so I thought I would do it as well!! LOL!! My wife thinks I'm nuts, too!!!!
Aaron Cameron
Is this belt useable on new nytro, or is it a different number as new nytro has different belt than the other yamahas ?
- 8K
