grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I wouldn't run it knowing they are bad. You don't want the extra heat under the gas tank for safety reasons. Also, loose clamps and flanges can eventually cause damage to the expensive flex pipes and header.
snow11
- Feb 17, 2014
- Skowhegan Maine
- 2007 yamaha apex
Mine are gone I can move the clamps with my hand I was thinking just take them off for now and run it for the rest of the season
BUT like you said my not be good just don't want to open anothing can of warms trying to get them 2 bolts out
Yannie
I'm a novice tinkerer and it was very painless. Soak the bolts and like grizz said use a hammer driver.Mine are gone I can move the clamps with my hand I was thinking just take them off for now and run it for the rest of the season
bmazbnytro
I changed mine in about a hour. It is a easy job if you plan it out before you dig in. Use the impact like Grizz stated is the key. If you don't have go buy one, you will be surprised at how many times you use it in your shop for just about everything you own. Some of the best advise my granddad gave me 25 yrs ago.
snow11
- Feb 17, 2014
- Skowhegan Maine
- 2007 yamaha apex
Well no luck getting them out tried everything that was talked about here now head's striped out
I just don't know what to do out side of drilling them out
snow11
- Feb 17, 2014
- Skowhegan Maine
- 2007 yamaha apex
And after reading though here someone said that after they got the bolts out they couldn't pull the exhaust Bach to get the new dounut in
can anyone confirm that
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Worst case scenario is you'll have to pull the flex pipes. Extra 5 minutes, no biggie. I've heard that some guys can get them on by massaging the joints enough to slide the new do-nuts on. I pulled my flex pipes.
NS FX NYTRO
I could,not squeeze my flex pipes back enough to get new donuts in. I removed the flex pipes, the bolts came out easily, and made the job 10 times easier.
If you can get a helping hand, one person can squeeze the flex pipes enough to shorten them while the other slides the donuts in. This is how I did it. Easy.
NS FX NYTRO
I could see that working, I was solo and couldn't do both.
If bolts turn out its still easier to just remove flex pipes.
snow11
- Feb 17, 2014
- Skowhegan Maine
- 2007 yamaha apex
You know was looking at them last night and was thinking if that could be done
I was afraid of braking them lol
bmazbnytro
Soak them with penetrating oil overnight, mine came out easy. Use good antiseeze when reassembling for future work if needed.
snow11
- Feb 17, 2014
- Skowhegan Maine
- 2007 yamaha apex
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
That is a wire guide that goes on the rear of the fuel tank. It holds the brake light wire over the back of the fuel tank.
snow11
- Feb 17, 2014
- Skowhegan Maine
- 2007 yamaha apex
Ok thanks but when I was taking the right side panel (if you're sitting on the sled) that's where it came from
