Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Standard warranty is one year longer on the cat. But I believe Yamaha is easier to deal with. This was preseason orders. I do like the bibs and jacket cat was throwing in. But they own that company.
super_rash
- Feb 24, 2014
I say, if you're a Yamaha guy, go with the Yamaha...if you're a Cat guy, well... go with a Yamaha ....hahahahahahActually, the dealer that I bought from sells both brands. He basically said, if you are a cat guy, go with the cat. If you are a Yamaha guy, go with the Yamaha. He also said the warranty and price were better for the yamaha.
DSimps10
- Oct 10, 2014
- Oxford Michigan
- 14 Nytro XTX
Thanks, this make sense to me now, never really play with boosted engines on Dynos. Good to know.12,5:1 AFR is around perfect for 10 psi boost. Over 13:1 AFR is to lean. I never run over 12:1 AFR in my sled, when loaded over 18 psi
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I like the fact that it makes this power at 8800 and 160 hp as low as 6500 and only 10 lbs of boost,should be a fun year,now all we need is snow.12,5:1 AFR is around perfect for 10 psi boost. Over 13:1 AFR is to lean. I never run over 12:1 AFR in my sled, when loaded over 18 psi
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I see they did not display torque numbers,does anyone know what it was?
**sj**
130ft lbs at 6500 and stays above 126 (low point at 7000) with a burst to above 130 between 7500-7900 (peaks at 131.1 at 7700) and back up to 129 at 8100 rpms!
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
So let me do the math here...i weigh exactly 170lbs. I'm EXACTLY in between the HP & Torque numbers. Soo that means i have a perfectly balanced machine. Soo I WIN...i can't wait for that first challenge!
**sj**
it means it has an extremely wide torque band ...it will pull and keep pulling....especially since you are 170 lbs. !
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
What it means is, i won't sleep tonight. That's right. 130 ft/lbs of torque = insomnia
sabrecat
Vendor
- Nov 7, 2013
Are they going to be limited to around 100 mph with 200 hp out of the box like the 1100 turbo cat is?
krm
- Apr 22, 2016
- ny
noAre they going to be limited to around 100 mph with 200 hp out of the box like the 1100 turbo cat is?
bleedyamaha
- Sep 28, 2013
- Northern Iowa
There's a video somewhere running them across a lake at 122+ mph I would think they won't restrict them. That's just part of the fun factor.Are they going to be limited to around 100 mph with 200 hp out of the box like the 1100 turbo cat is?
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
120 mph +. Book it
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
they really should go 130 with that kind of paw. But no new sled does. Nothing will ever have the aero like the ck3 had.
